Latest post 12-19-2009 4:58 PM by Steve at Sounds Heavenly. 5 replies.
Page 1 of 1 (6 items)
  • 12-01-2009 11:16 AM
    Beomaster 7000
    Help! can anyone tell me if the cd50 and the RX2 TT are compatible (simply) with the Beomaster 7000?
  • 12-01-2009 3:07 PM In reply to
    Re: Beomaster 7000
    The cd50 should work without problems ....it does with my beomaster 6500.
    I think the RX2 will need a phono pre-amp. The beomaster usually don't have these built in and I don't think the TX2 has one build in either.
  • 12-01-2009 7:10 PM In reply to
    Re: Beomaster 7000
    Thanks for the reply..... I was wondering if you can tell by the 7000's serial number if it had the preamp integral. My reading up on other websites tells me that some do & some dont....
  • 12-02-2009 2:53 AM In reply to
    Re: Beomaster 7000
    MrHilbert:
    My guess is that you can safely bet it doesn't. It never was a standard option on the BM7000 (nor 6500), and not that many 7000 systems were sold with a turntable anyway.
    But since the RX2 has RCA out and you won't get Datalink anyway, adding an external preamp will not be as much of a hassle as it could be (one 2xRCA - 5-pin DIN adapter after a regular preamp will do).
    The CD part should be fine, although be warned that the mismatch in looks will get annoying.
    -mika
  • 12-02-2009 7:45 AM In reply to
    Re: Beomaster 7000
    I think Steve at Sounds Heavenly (one of this site's sponsors) can provide you with a datalink to datalink phono pre-amp.
    It should be the best solution and will offer datalink control of the RX through your beomaster.
  • 12-19-2009 4:58 PM In reply to
    Re: Beomaster 7000
    Hi, thanks for the mention!
    No problem, please feel free to get in touch via my sponsor link below and I can sort out a pre-amp with a wiring loom to transmit Datalink (including cross-over links, as the BM7000 and RX2 have slightly different Datalink wiring).
    Just to confirm that the comments above are correct: Beogram RX does not have a pre-amp built in, neither does Beomaster 7000.  It is technically possible to fit an internal pre-amp to either the BM7000 or the RX 2, but I have never yet seen either of these be modified in this way.  So, you can normally be fairly sure that you will need an external pre-amp when connecting these devices.
    Kind regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
