Hi, thanks for the mention!
No problem, please feel free to get in touch via my sponsor link below and I can sort out a pre-amp with a wiring loom to transmit Datalink (including cross-over links, as the BM7000 and RX2 have slightly different Datalink wiring).
Just to confirm that the comments above are correct: Beogram RX does not have a pre-amp built in, neither does Beomaster 7000. It is technically possible to fit an internal pre-amp to either the BM7000 or the RX 2, but I have never yet seen either of these be modified in this way. So, you can normally be fairly sure that you will need an external pre-amp when connecting these devices.
Kind regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
