I have recently updated my Beo 5 Configuration Tool and had a quick look at it. I can`t find Beolab Penta any longer in the speakers list (only BL 6000 and BL 8000 from the older series are listed). I'm not sure if I remember right but I believe my old version offered Pentas also as a choice for speakers.
As I am running a 5.1 configuration with BL Pentas as front speakers, does that have any impact on controlling my system? To be honest I never understood why the config tool and the Beo5 needs to "know" which speakers are running. Does it make any difference and if so, which speaker should I choose from the list to substitute my Pentas?
|BV 7-32|BL 7-1|Ouverture|BL Penta|BL 6000|BL 2000|Beocom 6000|Beotalk 1200|MX 4000|Beoport|Beo4|Beo5|A8|A9|
