Latest post 03-19-2010 7:28 AM by hackel. 2 replies.
Page 1 of 1 (3 items)
  • 11-03-2009 11:03 AM
    Using Play, Stop, ... with an existing profil
    I have download a sony RDR profil for the BEO5, it works well with all the comands which are on the screen but when I want to use, for exemple, the "Play" button (by drag and drop the Play function on the button of the BEO5) nothing happen.
    Someting strange is that on the View Tab of the BEO5 configurator, the Play button seem to be OK only if the Play function is on the screen. If I change for page 2 (where there isn't Play at the screen) nothing happen.
    Another problem is that with all the non-profil B&O the sound doesn't work, even if the function 0:000:ALL:ANALOG_UP_1
    Thank you for your help.
    BV7-40, BL9, BL4000, BL2000, BV6-26, Beosound 5, Avant70
  • 03-15-2010 1:57 PM In reply to
    Re: Using Play, Stop, ... with an existing profil
    I have always the same problem with another profil. When I want to use arrow keys, colour keys, and the others buttons, they only works if there is the same function on the screen.
    This is very strange, did you manage to use the buttons even if the function is not on the screen ??
  • 03-19-2010 7:28 AM In reply to
    Nobody have the same problem ??? That's will be amazing if this problem happens only to me !!!
    Or does it mean you only use the screen to control other product ??
