I have download a sony RDR profil for the BEO5, it works well with all the comands which are on the screen but when I want to use, for exemple, the "Play" button (by drag and drop the Play function on the button of the BEO5) nothing happen.
Someting strange is that on the View Tab of the BEO5 configurator, the Play button seem to be OK only if the Play function is on the screen. If I change for page 2 (where there isn't Play at the screen) nothing happen.
Another problem is that with all the non-profil B&O the sound doesn't work, even if the function 0:000:ALL:ANALOG_UP_1
Thank you for your help.
BV7-40, BL9, BL4000, BL2000, BV6-26, Beosound 5, Avant70
