Hi there,
As this is my first post on this forum, just quickly an intro on how I got started with B&O. Ever since I got my hands on my grandfathers old Beomaster 1000 when I was about 10, I've been a fan of this brand and the sound it's products produce. The 1000 is still working, hooked up to a DVD/CD player!
Last week I also got the equipment my grandfather had purchased afterwards: a Beocenter 2800, with 2 sets of Beovox speakers. The problem I have now is that the Beocenter doesn't "do" anything when I plug the power cord in and choose for example the FM source. I tried a couple of things such as choosing other sources, also checked that the switch at the bottom is set to 220V. I don't see any lights in the band window, which normally should light up when powered on I guess.
The thing is that this equipment has just been standing there in my grandparents' living room for about 8 years without being used, and I suspect that this might be causing the problem.
Does anyone here have any tips on what I should check before asking a professional to check the machine? I'm pretty technical minded, but don't have much eperience with electronics.
thank you
best regards
Jazzy
