Latest post 10-18-2009 4:39 PM by elephant. 2 replies.
Page 1 of 1 (3 items)
  • 10-18-2009 8:40 AM
    Beoport BM-Link sound on headphone ok, no sound via ML
    HELP!! I have a Beoport connected to a Macbook with BM link. Everything works ok, sounds perfect on a headphone connected to the beoport, Powerlink is also working, but........ no sound on the other systems via ML.
    I have a Beocenter 9300 (radio, tape, cd) linked via a Beolink converter 1611, a Beovision 3-28 and 4 Beolab 6000's.
    Early options via a PC with Beoplayer worked only with radio, cd, dvd, tv etc. sound from other systems to the pc, not from pc to systems (same problem)
    I use a B&O ML distributor to connect Beovision, Beocenter and beoport.
    What do I have to do?!?!?
  • 10-18-2009 8:55 AM In reply to
    Re: Beoport BM-Link sound on headphone ok, no sound via ML
    Your Audio master (Beosound 9300) is not compatible with N.MUSIC, so you cannot distribute PC (or Mac) music to the main system.
  • 10-18-2009 4:39 PM In reply to
    Phil, do you think the hidden (by a black sticker) minijack port (reserved for future use) on the Beoport might be useful in this situation ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
