HELP!! I have a Beoport connected to a Macbook with BM link. Everything works ok, sounds perfect on a headphone connected to the beoport, Powerlink is also working, but........ no sound on the other systems via ML.
I have a Beocenter 9300 (radio, tape, cd) linked via a Beolink converter 1611, a Beovision 3-28 and 4 Beolab 6000's.
Early options via a PC with Beoplayer worked only with radio, cd, dvd, tv etc. sound from other systems to the pc, not from pc to systems (same problem)
I use a B&O ML distributor to connect Beovision, Beocenter and beoport.
What do I have to do?!?!?
