Latest post 10-15-2009 12:06 PM by vikinger. 2 replies.
Page 1 of 1 (3 items)
  • 10-15-2009 4:47 AM
    • ed7
    • Top 200 Contributor
    • Joined on 12-06-2007
    • uk
    • Posts 297
    Pre-owned
    Is there a way to convert the pre-owned music systems /beosounds radios once the analog signal switched off??or rendered obsolete?
  • 10-15-2009 5:22 AM In reply to
    Re: Pre-owned
    Analog TV is being switched off here in the UK (we lose ours  next month) but I think analog FM will be around for a while, especially as in-Car DAB has yet too catch on.
    I don't think there is an elegant solution but you may be able to do something with one of the FM transmitters designed for iPods etc or simply buy an external DAB tuner.
    Simon
  • 10-15-2009 12:06 PM In reply to
    Re: Pre-owned
    Using a Roku/Pinnacle N Radio decoder works for me: just input it to your auxiliary connection using a 5pin DIN plug to phono lead.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
