I got a Beogram 1202 that is working perfectly but the 5 pin DIN plug needs to be soldered back on.
How is this done? I got 3 wires as I recall and 5 pins. One is black the other white. I guess left and right?
From the manual. A little continuity testing should reveal which is which!
Thank you Peter.
That should do the trick.
