Latest post 10-08-2009 11:52 AM by Friedmett. 2 replies.
Page 1 of 1 (3 items)
  • 10-07-2009 3:46 PM
    Beogram 1202 how to solder the 5 pin DIN back on?
    I got a Beogram 1202 that is working perfectly but the 5 pin DIN plug needs to be soldered back on.
    How is this done? I got 3 wires as I recall and 5 pins. One is black the other white. I guess left and right?
  • 10-07-2009 4:31 PM In reply to
    Re: Beogram 1202 how to solder the 5 pin DIN back on?
    From the manual. A little continuity testing should reveal which is which!
  • 10-08-2009 11:52 AM In reply to
    Thank you Peter.
    That should do the trick.
