I had posted earlier that I had picked up a beomaster 1600, the volume does not work and it is stuck at 2 position, I used its tape output and connected to my current system, and I listened to FM radio, and then connected a turntable to it.
The sound? Well the best way I can described is that it was not noisey, it was laid back, kinda warm, but lacking highs a little, but I loved it, it has great midrange where most of the music is, I am sure all of you know this.
I have taken it out for repairs, and it would be a while before it gets looked at, but I am told that it will be fixed.
BUt in the meantime, I was wondering, which is the best sounding beomaster in your opinion, and why? Secondly, how does it compare to high-end audio components, such as Audio Research, Krell, Wadia, Mccormack, well you get the picture.
Based on your opinion, I will buy a properly functioning beomaster, let me know the max price I should pay for it.
Looking forward to be a 100% BEOGUY.
Happy Listening.
