You can connect the BM5 also to a non B&O TV, for this you need a DVI to VGA cable (if your TV has a VGA input). It works also with a component cable, but the quality is not so good. Then you see on the TV the complete Menue (N.Radio, N.Music, Web, Photo).
Unfortnatly, this is all you can do at the moment, because you can not control the BM5 with the Beo 4 or 5 to select the web and photo feature, because the IR connection socket at the BM5 is not activated.
All this should work with the next firmware update (I'm waiting since 6 month for this...), then you need a separat IR-Receiver which you connect to the BM5.
the hoping Kai...
