Latest post 08-27-2009 4:21 PM by adro. 2 replies.
Page 1 of 1 (3 items)
  • 08-26-2009 4:22 PM
    • adro
    • Not Ranked
    • Joined on 08-26-2009
    • Posts 23
    • Gold Member
    Web and Photo
    Hallo.
    Is web and photo available only if Beo5 is connected to a Beo tv, or is there any point in connecting the system to another tv?
    Atle.
  • 08-27-2009 7:36 AM In reply to
    Re: Web and Photo
    You can connect the BM5 also to a non B&O TV, for this you need a DVI to VGA cable (if your TV has a VGA input). It works also with a component cable, but the quality is not so good. Then you see on the TV the complete Menue (N.Radio, N.Music, Web, Photo).
    Unfortnatly, this is all you can do at the moment, because you can not control the BM5 with the Beo 4 or 5 to select the web and photo feature, because the IR connection socket at the BM5 is not activated.
    All this should work with the next firmware update (I'm waiting since 6 month for this...), then you need a separat IR-Receiver which you connect to the BM5.
    the hoping Kai...Wink
  • 08-27-2009 4:21 PM In reply to
    • adro
    • Not Ranked
    • Posts 23
    • Gold Member
    Re: Web and Photo
    Thank you hoping Kai.
    I will join you, and hope that we will not have to wait another 6 months for this update.
    Atle.
