Latest post 08-26-2009 2:48 AM by mbee. 9 replies.
Page 1 of 1 (10 items)
  • 08-24-2009 3:15 PM
    beovision 10 hdmi ports
    The new bevision 10 has only 2 hdmi ports....why so little????
    Do they never listen to there customersHmm
  • 08-24-2009 3:21 PM In reply to
    • ed7
    • Top 200 Contributor
    • Joined on 12-06-2007
    • uk
    • Posts 297
    Re: beovision 10 hdmi ports
    It is a new sales strategy !!!,you need to buy two setsSurprise
  • 08-24-2009 3:27 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    A HDMI Expander can be connected to the HDMI B-socket.
    I don't really understand why they don't put more HDMI sockets on it in the first place...
  • 08-24-2009 6:22 PM In reply to
    • moxxey
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    koning:
    Why so shocked? It's based on the BV8-40 chassis - we've been discussing this for months!! The BV8-40 has 2 x HDMI sockets.
    Another BV10 thread, I see.
  • 08-25-2009 10:21 AM In reply to
    Just wondering where you find the BV10 spec? Thanks.
  • 08-25-2009 10:31 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    I think that it was on a financial report that B&O stated that the 10 will be based on the 8 technology, with another speaker and design... Maybe it was a news from an insider, not sure. But that fact is sure.
    Concerning the 2 sockets, I was hoping that B&O could change only the last circuitry in the bv8 chassis to add some sockets without any development cost (as it's basically an integrated switch with more ports, a cheap circuit which doesn't add complexity to the electronic architecture), but B&O seems to have choosen to keep the whole bv8 package without modifying anything.
  • 08-25-2009 3:01 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    mbee:
    Unfortunately/fortunately it's called 'economies of scale'. It makes a lot of sense. Create on chassis and then run it across as many TVs as possible.
    I doubt the BV7-55 will have a different chassis from the BV7-40. Different panel, sure, but same chassis.
  • 08-25-2009 3:40 PM In reply to
    >>add some sockets without any development cost << Software would change I would think, so you have testing etc.
    There is never enough connections ..... I think it's very wise that they use exactly the same platform ..... BV8 40 is a solid TV and having an alternate design is great and in the end many of us I would think are just after that. Design.
    We all lived and still live with a single AUX / Line in .............
  • 08-25-2009 5:15 PM In reply to
    so where are the pics and specs of this new telly then???
    Confused
  • 08-26-2009 2:48 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    Not far from here :
    Big Smile
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
