Note that in the software, you do not add the DVD2 as an audio product, but as a DVD player, after you've added the TV.
I got this result, but you need to refine this as I did not know which version of BV you've got:
************************* VIDEO SYSTEM SETUP **************************
BeoVision 7 - 40"MKIII TV
DVD 2 (VR 1)
Connection Video
Please note: BeoLab 7-2 must be connected to "Power Link Centre"
(not "Cinema Centre"!).
Display 1-2 (DVI-D out).
Connector for screen or projector.
A screen is connected to Display 1 and projector must be connected to Display 2.
HDMI-IN (A-D) (High Definition Multimedia Interface).
The HDMI sockets can be connected to any HDMI video source or PC.
Please note:
You can view 2 HDMI sources at the same time.
IR IN.
Connect the receiver cable to the IR-socket and plug it into the
6-pin terminal block of the IR-eye.
IR1+2.
The socket is used to check the IR-signal to the projector.
AV1 - AV6.
AV1 is used for AV connection of equipment such as a DVD recorder, VCR, HDR or
set-top box. (V MEM). 2-way communication from TV to product connected. AVL.
AV2 is used for AV connection of additional equipment such as a
digital satellite receiver (DTV).
1-way communication from TV to the product connected. AVL.
AV3 is used for AV connection of additional equipment such as a DVD player.
AV4 is used for AV connection of additional equipment. 1-way communication
AV5 is used for AV connection of additional equipment such as BeoMedia or a PC.
AV6 is used for AV connection of additional equipment such as a camera.
Connect the aerial to the aerial input of the VR 1.
Connect the aerial output of the VR 1 to the aerial input of the
TV-set using a coaxial cable.
Speaker.
Connecting speakers is made in the Power Link sockets.
Speakers is connected to the Power Link sockets as single or
pair. If pair a Power Link splitter is required.
In TV the centre speaker is connected to the (centre) socket.
If extra centre speaker is to be connected, a Power Link splitter is required.
Selecting option on the TV-set
Option programming with Beo5:
Option programming is made with the Beo5 Configuration Tool.
Options settings are sent to the products by means of the Setup menu in Beo5
Option: OPTION 2, with Beo4
Press: | Display:
STANDBY + LIST at the same time | OPTION?
GO | V.OPT
2 | Observe confirmation
| from BeoVision
Note!
It is not possible to connect an extra plasma screen to the TV.
If the VTR modulator frequency interferes with other signals in the
UHF range, adjust the modulator frequency by means of the screw
on the rear panel of the VTR.
The recommended distance between channels in the UHF range is
16 MHz.
************************* AUDIO SYSTEM SETUP **************************
BeoSound 9000
Connection Audio
Connect the aerial to the aerial input of the audio master.
Selecting option on the audio master
Option: OPTION 0, with Beo4
Press: | Display:
GO | V.OPT
LIST | A.OPT
0 | Observe confirmation
| from AudioMaster
********************* AUDIO/VIDEO/LINK SYSTEM SETUP *******************
Connection
Connect the Master Link socket of the audiomaster to the MASTER LINK
socket of the TV-set using a BeoLink cable.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beo5
The following remote controls may also be used:
Beo4
Setup for Beo5 remote control:
Programming Beo5 to operate products, Option programming and
zones, is done with the Beo5 Configuration Tool.
