I just purchased a few pieces of vintage B&O audio equipment and am very excited listen to them when I get everything working.
Withe the Beogram CD X, if I unplug the power and plug it in it sounds like something is going on in the Beogram CD X, but when I hit play it won't spin or play the CD and the display will show "2".
After the first turning anytime it is turned on it gives a little (5*) rotation on the CD. Same thing when I hit Play.
I did a google search but found nothing that helped me, except a couple post's about a Beogram CDX, which is the generation after my CD X.
Any help would be greatly appreciated. -I also now regret having destroyed my fathers vintage Realistic Electrostat-2a (when they had a quality product if I may say so) speakers when I was younger and hooked them up to a very powerful Marantz amp -I would love to have some eletrostatic speakers, but can't afford them unless I can find them in the same price bracket I got the B&0 Beomaster 3000, Beogram CD X, and Beocord 2000 (which doesn't work either, but I don't use tapes so....).
