1st March February 2012
Latest post 02-01-2012 7:23 AM by chartz. 79 replies.
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
Re: Privat survey of Beolab 5000 - Beomaster 5000 producs
beaker:Here are the details of my newly aquired 5000 system
As offered to me: Welcome to the club!
Have you had an opportunity to try it out yet?
superbeatnik
- Joined on 08-04-2008
- Posts 9
hi everyone
here are the informations on my beolab 5000
s/n 56982
serie: 10
teak
I found it with a beogram 1800 turntable both for 40 euros. needless to say I was quite happy this day..
classic
- Joined on 04-16-2007
- Venø - Struer / Denmark
- Posts 224
Superbeatneak,
This is a very fine bargin, remember the Beogram 1800 is actually er very fine and rare turntable too, specially if it is in good coindition.
/Frede
Beolab 5000 - "If another amplifier sounds different then it needs repair!"
classic
- Posts 224
I think it is time for a sub- result, I do hope for many more input in this Beolab 5000 club survey.
Here you can see my estimate of the information I have so far for the Beolab 5000.
/Frede
classic
- Posts 224
And for the Beoamster 5000
/Frede
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Frede! I have no idea how I missed this thread. I will get the numbers for you straight away.
Andy T.
classic
- Posts 224
Jandyt:
Ok Frede My BeoMaster 5000 Type 2005 is Serie 07 Number 34097 My BeoLab 500 Type 5303 is number 46808, unfortunately, a scratch runs through the serie number. It is either 08 or 03. Hope this helps, and sorry for the delay.
Andy T.
Hi Andy,
I am happy to see your input and actually the Beolab expanded the 'counting window' a little, which is most appriciated.
By the way your Beolab is of series 8 - which means means it is produced in 1969 (I think )
/Frede
superbeatnik
- Posts 9
my beogram 1800 is in very fine condition except a few scratches on the plexiglass cover, which could be removable with a good compound. the only problem I have with it is the very rare and/or expensive sp10 cartridge. do you know if there are some cheapest replacement adaptable cartridge existing?
classic
- Posts 224
superbeatnik:
Do you have a SP10 perhaps without the diamond? If so you can have it re-tipped which is not very expensive. There are some possibilities on the internet, where you can find B&O pick-up's but if you really wish to have the SP10 with correct nude-line sfarical diamond, the only good solution the original or the original re-tipped.
/Frede
superbeatnik
- Posts 9
thanks for the answer!
I have the sp10 with the stylus, but it's bent, so I have to replace it (the stylus)... any adress maybe?
pascal.
classic
- Posts 224
superbeatnik:
pascal.
Yes of course: http://www.schallplattennadeln.de/
This company is doing a very good job and several of the members on this site has allready used this service.
You can see here which diamond type was the original for the SP10. This can help you when ordering, I hope.
/Frede
Peter
- Joined on 02-12-2007
- Posts 9,572
The SP12 was a recognised upgrade for the SP10. The rare cartridge is probably the SP8/9 which was that fitted to the Beogram 3000 type 5210.
Saskwatch
- Joined on 11-11-2009
- Posts 1
Just signed up, just bought a BL5000, type 5303, Serie 2, serial number 66407
Beomaster 5000S Type 2007, serie 01, serial number 16757
also have a Beomaster 5000 type 2013, Serial number 74824, serie 01
I knew the Amp was defective when I bought it, am always up for a challenge! Turned out to have two shorted transistors in the right channel, looks like it crosses to a 2N5320, and the 3000uF/50V electrolytic hisses and leaks chemicals. The original brand is no longer available according to the website, does anyone have any idea of a suitable replacement?
Thanks,
Bert
classic
- Posts 224
Hi Bert,
Tks. for the ID of your products.
There are no direct replacement transistors - and please be very careful - I never use anything else than the originals for this amplifier. When I can use the original is because I use doner parts from other Beolab products.
The capacitors - you can use any new parts e.g. 4700uF / 100V for output and power supply. Please use good quality parts and for your own convinience - use parts with the original diameter. It will be more easy to mount these.
/Frede
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
I agree with Frede. The 2N3055 transistors can still be found but the risk of receiving counterfeit transistors exists, even from trusted dealers. I was lucky to buy a small amount of New Old Stock RCA originals a couple of years ago, the same type as B&O used back then, but I've also seen fake products, listed at Ebay and even from my own (otherwise superb) component dealer.
Use original parts if you can. Semiconductors doesn't wear out so even used transistors are better than buying new and risking a tragedy.
Read more here: http://forum.beoworld.org/forums/t/2388.aspx
Folke
- Joined on 10-24-2008
- Stockholm, Sverige/Sweden
- Posts 30
Got a Beomaster 5000 tuner today, so I had to revive this thread!
NR 5000
TYPE 2005
Serie 01
No 15715
Palisander
EDIT: Wow! Number 270 out of 12.000 produced. Almost a prototype...!
BG 6000 Quad (two!), BM 3000, BM 5000 (2005), BV S45, BV M70 with trumpet stands
burantek
- SE USA
- Posts 6,214
Folke:Got a Beomaster 5000 tuner today, so I had to revive this thread!
Congrats Folke!
burantek
- SE USA
- Posts 6,214
Frede et al,
Another tuner for your list... Does this expand the Serie 01 list by 51 units?
Beomaster 5000 [2005] (Teak)
No. 16594
Serie 01
classic
- Posts 224
Thanks for the registration, the result of the Serie 01 count - see below.
As you see your product did not expand the number count of serie 01 but is a most valued input for me. I have now a 'very good picture' of the quantities of the Beomaster and Beolab production quantities.
Thank you very much
/Frede
Claus
- Joined on 11-05-2009
- Copenhagen
- Posts 41
Hello list & Frede-Classic
Some time ago I got my hands on a pair of Beolab 5000s and one Beomaster 5000.
They are:
Beolab 5000: Type 5303, Serie 04, No. 32000, E-4 (Oak)
Beolab 5000: Type 5303, Serie 10, No 57981, P-3 (Palisaner/Rosewood)
Beomaster 5000: Type 2005, Serie 03, no. 61537, E-4 (Oak)
Looks like it's only the one in the middle that ads to the list - expanding the Series 10 with only 4
Btw: The Oak-versions must be rather rare (and it's a bit pale - I'm not sure that I like it that much).
Frede, have you got any idea of the distribution between Teak, Rosenwood/Palisander and Oak/Eg
- Claus
- Claus Beolab 5000 (x2), Beomaster 2400-2 & 5000, Beogram 2400/MMC20E, Beovox S30, S45 & S75, M75 - and growing...
burantek
- SE USA
- Posts 6,214
Hi Claus,
Welcome to BeoWorld and the 5000 club!
I have never heard of... nor seen a set in Oak... Are they "factory" or perhaps redone?
Could you post a pic or two?
Claus
- Copenhagen
- Posts 41
Thanks Burantek,
Here is a pic that shows the Oak (as well as the one in Rosewood/Palisander).
I'm sure it's "factory" because the label says "E-4" (where Rosewood/Palisander is "P-3" - and Teak is either "T-1" or "T-2") I remember this from working in the Radio-TV business (app 1975-1985) - and selling a lot of B&O.
Sorry about the state they are in... Haven't done anything to them yet (time and other projects). As you can see, the former owner has swaped the small wood panels at the bottom (so it's Rosewood on the Oak Beolab and vice versa). And the 220 Volt plug on the Beomaster is a "female" - you can imagine that the live-plug must have been a "male" with 220 V on the two pins sticking out. Crazy!
burantek
- SE USA
- Posts 6,214
And thank you, Claus!
Well... there they are! Looking forward to what Frede can add to this.
I am about to have several cabinets redone. I had inquired about other wood species options on another thread, so I find this not only incredibly interesting, but also very timely!
