Hi Guys
I'm now finished with our living room, and I have started all the cable stuff.
My B&O dealer told me to use B&o powerlink MKIII with the blue wire (Digital) for all ICE power speakers and not the aftermarket cable, but I thought that the best thing was to use the MKII full mounted for all speakers, today I have Beolab8000 as rear speakers, but maybe later I will use Beolab3.
For the Beolab5 I'm using the cable that followed with the 5's, so I will cut them and solder new connectors on the cable.
Which cable is the best for the S/PDIF and scart signal? I have to make a 10m scart between the Beovision5 and HDR2 and 3m S/PDIF between Besound 9000 and Beolab5
One more question: I have now taken the Beovision5 in use, but what is it on the plasma screen, some kind of 'film' coating on the plasma screen or what? It seems like that the coating somehow is polished away in some area, there is some stripes that is very visible when the BV5 is turn off and from the side it's very visible with sunlight on the screen? (I haven't cleaned the screen!
Remember that I can't use the finished cables because I can't get the connectors in the pipes in the floor, only the cable itself.
