I have added a beolink converter and a beolab 2000 to my setup but it does not work.
Current setup
Beosystem 5500 (beomaster 5500) connected to beovox s80.2, mcl to mcl 2a and cx50 in a linkroom. I sometimes connect a lx2500 to the aux datalink and can then control the tv from the linkroom.
Today I connected a beolink converter 1614 s/w 1.0 and beolab 2000 to the aux datalink but it did nor work.
The beolab 2000 lights up a red light to the left in the display and a red light to the right in the display if the timer button is pressed. The red light to the right flashes if it receives ir from a beolink 1000. However, it only flashes if “menue” is pressed and for the next command after “menue”. I have never tried the beolab 2000 in another setup and do not know if it work, same for the converter.
Is there an obvious problem with this setup or should I suspect that something is wrong with the beolink converter or the beolab 2000.
Grateful for answers or tips
Hans
