Latest post 07-24-2009 3:06 PM by djram. 1 replies.
Page 1 of 1 (2 items)
  • 07-23-2009 12:49 PM
    • djram
    • Not Ranked
    • Joined on 08-26-2007
    • Posts 78
    • Gold Member
    adding a ml product to datalink through 1614, what is wrong
    I have added a beolink converter and a beolab 2000 to my setup but it does not work.
    Current setup
    Beosystem 5500 (beomaster 5500) connected to beovox s80.2, mcl to mcl 2a and cx50 in a linkroom. I sometimes connect a lx2500 to the aux datalink and can then control the tv from the linkroom.
    Today I connected a beolink converter 1614 s/w 1.0 and beolab 2000 to the aux datalink but it did nor work.
    The beolab 2000 lights up a red light to the left in the display and a red light to the right in the display if the timer button is pressed. The red light to the right flashes if it receives ir from a beolink 1000. However, it only flashes if “menue” is pressed and for the next command after “menue”. I have never tried the beolab 2000 in another setup and do not know if it work, same for the converter.
    Is there an obvious problem with this setup or should I suspect that something is wrong with the beolink converter or the beolab 2000.
    Grateful for answers or tips
    Hans
  • 07-24-2009 3:06 PM In reply to
    • djram
    • Not Ranked
    • Posts 78
    • Gold Member
    Update
    Update
    I have now consulted the pcg-software and apparntly I need the 1611 instead of the 1614. Am I right that the 1614 can be updated to a 1611 by changing the ic inside the unit.
    A new question.
    The pcg-software does not give masterlink and beolab 2000 as an option in a link room if beosystem 5500 is used as audio source in the main room If a beosystem 6500 is used in the main room the pcg-software gives masterlink and beolab 2000 as an option in the link room and suggests a beolink converter 1611 connected to aux audio link on the beomaster. I tought that the beomaster 5500 (beolink sticker on the back) and 6500 had the same link capabilities. Is that true?
    Regards
    Hans
