Latest post 12-01-2009 5:40 AM by Søren Hammer. 10 replies.
Page 1 of 1 (11 items)
  • 07-23-2009 7:09 AM
    Beogram 4002 distortion
    Hello, I am the lucky owner of a now fully functioning BG 4002. But I have a small problem: When the stylus gets closer to the center, the amount of unwanted distortion increases! At the last tune on record side the sound is horrible! It even does that with all of my new 180 gram records...
    the stylus is an MMC20 CL which normally sounds fantastic...
    Any help, please?
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 07-23-2009 9:40 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 4002 distortion
    Does it track properly ?
    Are the arms parallel at all times ?
    Is the tracking force set correctly ?
  • 07-23-2009 2:40 PM In reply to
    It is tracking well
    Arms are parrallel always
    I don't have a stylus weight, but the MMC20CL is adjusted to 1 Gram, according to the tracking force adjustment window(I know it can drift over time)
  • 07-23-2009 4:34 PM In reply to
    • Dillen
    • Posts 5,008
    1g sounds a bit low, even for a CL cartridge and you're right in assuming that the tracking force
    scale shouldn't be trusted 100% anylonger.
    Most original cartridges have hardened suspensions to different extents by now.
    Try increasing to 1.2g or even 1.4g if for nothing else than the diagnosis.
    If the cartridge is fine, it won't damage anything.
  • 07-24-2009 5:26 AM In reply to
    I tried to increase to 1,2. Much better, but there is still a very small amount of audible distortion, I might try 1,3 grams later
    Thank you for the advice Martin ^^
  • 08-08-2009 8:03 AM In reply to
    • DSJR
    • Not Ranked
    • Joined on 11-01-2008
    • Suffolk
    • Posts 31
    These cartridges were temperature sensitive and should sound much better in clarity and tracking during the summer months. try shining a small spotlight on the deck, not close enough to risk damaging the lid, but enough to further warm the playing area under the lid, which the electronics inside the deck should help with too. Aim to get the cartridge up to 22 degrees C at least. It certainly worked on new 20CL's I found. I'm not sure if the re-builders out there change the suspension on re-tipping, and if they do, whether they use a more temperature-stable material these days. At least you can get the CL done to a beautiful standard by Axel, judging by the pictures posted.
  • 11-16-2009 12:43 PM In reply to
    Hello, I still have the problem... The Turntable is audibly distorting about tho thirds though a record. It does that with my MMC20CL and MMC20S cartrigdes, The arms are still tracking 100% parallel, and the tracking force is set to 1,5g, which is the maximum setting, though I have tried everythng between .8 and 1,5. The turntable clearly sounds better when I increase the tracking weight. The Beogram sounds fantastic in the start of the record, and I suspect that the rubber suspensions og the cartrigdes are hard.
    Do you think that the problem lies in the Beogram or the MMC20 cartrigdes? Just in case, as I am soon preparing to send the MMC20CL to Axel for refurbishing with a Shibata diamond...
  • 11-16-2009 1:56 PM In reply to
    • AdamAnt316
    • Not Ranked
    • Joined on 08-17-2009
    • Massachusetts, USA
    • Posts 68
    Actually, the problem may lie with your records themselves. Inner groove distortion can result from a record being played with a turntable which is not properly set-up with regards to the cartridge and stylus. Most, if not all, Beograms shouldn't have this problem, since the cartridge/stylus can only be mounted one way. Try buying a brand new record, and play it a few times with your Beogram, and see if you still get this effect. Hope this helps.
    -Adam
    3000 | RX 2 | RX | TX 2 | 8000 | 1800
    Is there such a thing as too many Beograms?
  • 11-16-2009 2:33 PM In reply to
    Thank you for your response
    I have tried several brand new records, but there is still audible inner groove distortion. A Pioneer Pl-223 with Ortofon OM5, I once had, would never produce audible distortion, and when I try my old and new records on my Father's Beogram 8002, there is almost no distortion at all.
    -Søren Hammer
  • 11-29-2009 5:50 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Soren,
    I may have an interesting solution for you.
    I remember that I had one of these turntables for repair a couple of years ago, and it was also distorting on only certain areas of the LP. I finally traced the problem to the 2 aluminium plates - the large one surrounding the platter, and the smaller one above the control panel.
    They were not stting EXACTLY horizontally, and there was a small amount of friction between the plates, and the moving part of the arm.
    It was caused by the fact that the chassis poles which stick up into the holes on the underside of the plates were not exactly aligned.
    I solved the problem by taking a slightly larger drill-bit, and widening the holes on the underside of the plates - drill slowly and carefully, not to penetrate the platter's upper-side. Then the poles fitted into the holes perfectly, and there was no more distortion.
    Regards
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 12-01-2009 5:40 AM In reply to
    Hello Menahem
    I have contacted that technician who replaced the speed changing relay. He is saying that those plate weren't levelled when he did the repair. I have to send the turntable to repair with my BG 4000. Thanks for the advice :)
