1st March February 2012
07-23-2009 7:09 AM
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
Hello, I am the lucky owner of a now fully functioning BG 4002. But I have a small problem: When the stylus gets closer to the center, the amount of unwanted distortion increases! At the last tune on record side the sound is horrible! It even does that with all of my new 180 gram records...
the stylus is an MMC20 CL which normally sounds fantastic...
Any help, please?
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Re: Beogram 4002 distortion
Does it track properly ? Are the arms parallel at all times ? Is the tracking force set correctly ?
Søren Hammer
- Esbjerg/Denmark
- Posts 554
It is tracking well
Arms are parrallel always
I don't have a stylus weight, but the MMC20CL is adjusted to 1 Gram, according to the tracking force adjustment window(I know it can drift over time)
Dillen
- Posts 5,008
1g sounds a bit low, even for a CL cartridge and you're right in assuming that the tracking force scale shouldn't be trusted 100% anylonger. Most original cartridges have hardened suspensions to different extents by now. Try increasing to 1.2g or even 1.4g if for nothing else than the diagnosis. If the cartridge is fine, it won't damage anything.
Søren Hammer
- Esbjerg/Denmark
- Posts 554
I tried to increase to 1,2. Much better, but there is still a very small amount of audible distortion, I might try 1,3 grams later
Thank you for the advice Martin ^^
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Hello, I still have the problem... The Turntable is audibly distorting about tho thirds though a record. It does that with my MMC20CL and MMC20S cartrigdes, The arms are still tracking 100% parallel, and the tracking force is set to 1,5g, which is the maximum setting, though I have tried everythng between .8 and 1,5. The turntable clearly sounds better when I increase the tracking weight. The Beogram sounds fantastic in the start of the record, and I suspect that the rubber suspensions og the cartrigdes are hard.
Do you think that the problem lies in the Beogram or the MMC20 cartrigdes? Just in case, as I am soon preparing to send the MMC20CL to Axel for refurbishing with a Shibata diamond...
AdamAnt316
- Joined on 08-17-2009
- Massachusetts, USA
- Posts 68
Actually, the problem may lie with your records themselves. Inner groove distortion can result from a record being played with a turntable which is not properly set-up with regards to the cartridge and stylus. Most, if not all, Beograms shouldn't have this problem, since the cartridge/stylus can only be mounted one way. Try buying a brand new record, and play it a few times with your Beogram, and see if you still get this effect. Hope this helps.
-Adam
3000 | RX 2 | RX | TX 2 | 8000 | 1800
Is there such a thing as too many Beograms?
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Thank you for your response
I have tried several brand new records, but there is still audible inner groove distortion. A Pioneer Pl-223 with Ortofon OM5, I once had, would never produce audible distortion, and when I try my old and new records on my Father's Beogram 8002, there is almost no distortion at all.
-Søren Hammer
yachadm
- Joined on 06-24-2007
- Jerusalem, Israel
- Posts 687
Soren,
I may have an interesting solution for you.
I remember that I had one of these turntables for repair a couple of years ago, and it was also distorting on only certain areas of the LP. I finally traced the problem to the 2 aluminium plates - the large one surrounding the platter, and the smaller one above the control panel.
They were not stting EXACTLY horizontally, and there was a small amount of friction between the plates, and the moving part of the arm.
It was caused by the fact that the chassis poles which stick up into the holes on the underside of the plates were not exactly aligned.
I solved the problem by taking a slightly larger drill-bit, and widening the holes on the underside of the plates - drill slowly and carefully, not to penetrate the platter's upper-side. Then the poles fitted into the holes perfectly, and there was no more distortion.
Regards
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Hello Menahem
I have contacted that technician who replaced the speed changing relay. He is saying that those plate weren't levelled when he did the repair. I have to send the turntable to repair with my BG 4000. Thanks for the advice :)
Page 1 of 1 (11 items)
