Hi Everyone,
After years of B&O ownership i thought that I had better try to understand it properly!
As B&O do not supply drivers for a Vista 64 bit O/S (unless you know better), I lost the use of my Beo 3's in my study. I asked B&O suppport and 2 dealers for a solution, none of which were forthcoming.
I figured out from this site that a Beo link Active would do the trick, bought one, wired it up (with eye) and it worked, great so far............
Ignoring the adage of if it works leave it alone, I bought a lead from Sounds Heavenly and attepted to get an external device working from the PC socket on the box (other threads refer to this). It did not work first time, and I must have changed either a config or an option, so now the eye does not respond to the Beo 4.
I can though access the radio only manually from the eye, I guess that this is because the radio was the last source used?
Any guidance gratefully accepted.
Nigel
