Latest post 06-04-2007 12:15 PM by Mr10Percent. 2 replies.
Page 1 of 1 (3 items)
  • 06-04-2007 7:46 AM
    Earset 2 & PC/Laptop
    Has anyone tried to connect their Earset 2 to their laptop/pc? Would be fantastic if the Earset 2 could also be used as a headset for Skype or other voice applications on PC/Laptop
     Karel.
    The race for quality has no finish line- so technically, it's more like a death march.
    Filed under:
  • 06-04-2007 9:14 AM In reply to
    • Toubro
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 263
    Re: Earset 2 & PC/Laptop
    Have a look at this thread in the Beo-PC forum http://forum.beoworld.org/forums/thread/18486.aspx
  • 06-04-2007 12:15 PM In reply to
    Karel,
    Already done it with a Belkin USB bluetooth adapter. Works straight forward and simply once you have trained the signal to the ES2.
    However, the problem is....and this occurs with all 3 earsets (Motorola, Nokia and B&O) I have had is that with Skype, there is always a progressive delay forming over time between you and the person you are talking to. So say 10ms becomes 20ms.....and before you know it, there is a 10 second delay.
    To overcome this - and I am a big skype user, I have reverted to the Earset 1 Mobile and a aircraft twin mono jack plug. The solution is neat (aparently ES1 can be traditionally soldered to a custon plug) and totally comfortable. Best Skype earpiece I have ever had. Another very underrated B&O product.
    So in essence, ES2 is possible but forms a delay. Wire rather than wireless is better.
    10%
