I dont have my BS5 infront of me but it goes something like this:-
1. Find the station (horizontal position) you want to add to favourites, press and hold GO.
2. At the same time, rotate the wheel and Favourites should appear.
3. Release the GO when the favourite number slot is horizontal (otherwise it will over-write any existing station that is in the horizontal position).
It may be as above or if not, replace the wheel in 2. with the leaver.
10%
