Latest post 06-17-2009 1:16 AM by OKA. 2 replies.
Page 1 of 1 (3 items)
  • 06-16-2009 1:39 AM
    • OKA
    • Not Ranked
    • Joined on 12-03-2007
    • Denmark
    • Posts 15
    Adding N.RADIO stations to favorite list
    I am not able to add a N.RADIO station to the favorite list on Beosound.
    When I follow the instructions and go to favorites, press GO, select a number or a colored list,  release GO, then  nothing happens.
    I have tried to add stations to the coloured list in Beoplayer and that works fine, but not all stations are there and I don't think it is possible to assign a station to a number in Beoplayer.
    Any suggestions?
  • 06-16-2009 3:55 AM In reply to
    Re: Adding N.RADIO stations to favorite list
    I dont have my BS5 infront of me but it goes something like this:-
    1. Find the station (horizontal position) you want to add to favourites, press and hold GO.
    2. At the same time, rotate the wheel and Favourites should appear.
    3. Release the GO when the favourite number slot is horizontal (otherwise it will over-write any existing station that is in the horizontal position).
    It may be as above or if not, replace the wheel in 2. with the leaver.
    10%
  • 06-17-2009 1:16 AM In reply to
    • OKA
    • Not Ranked
    • Denmark
    • Posts 15
    You are quite right. It was step 1 that I was missing.
    It is not enough to listen to the the station that shall be stored, it has to be selected from the start, as you write.
    Thank you.
