Hi All,
I've been having some trouble with my DVD1 (connected to an Avant via SCART and digital Co-ax). Whenever I switch from DVD to another source the sound of the DVD continues to play yet the picture does change. After some tests it seems like this is down to the digital coax as if I remove it and run both sound and picture through the SCART this does not occur.
Before I lose the added quality of the digital sound link (and throw a rather expensive cable in the bin!) I was wondering if anyone knows how to add an 'OFF' button to the Beo5 that will just switch off the DVD1 and not the whole Avant and all peripherals attached?
Since the DVD1 does have an off button on the front I assume there must be a way to activate this feature via remote. I was advised that this was simply not possible via a Beo4, but am hoping this is not the case for the Beo5.
So far I've found the 'Standby' button in the Beo5 Config V3 tool but this is to switch of the Avant et al. Is there a button just for the DVD1?
Thanks for your help as always guys!
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
