Thanx
It's very scary putting so much force when pulling of the fret. I've found that forcing you fingertips in the "Redline", pushing the fret away with your fingernails, works perfect.This way you feel how much pressure you apply and avoid overshooting and breaking the frame.
And they look perfect inside even the filling and the electronics.
RL35, Type 6515, Serial: 04900812
I red in the RL60 forum that changing the electronic is recommended.
Wat about that for this type or others or at all?
***As an aside, while you have the speakers in bits, it is worth considering replacing the electrolytic capacitors in the crossover circuits, as the originals will probably have dried out by now, reducing the treble response.***By Stevem
Thanx again
The Doctor
