Latest post 06-04-2009 1:39 AM by mediabobny. 6 replies.
Page 1 of 1 (7 items)
  • 06-02-2009 9:26 AM
    Cassette cleaning fluid for Beocord 9000...........
    Are they safe?
     and which brand is the best for BC9000?
  • 06-02-2009 11:12 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Cassette cleaning fluid for Beocord 9000...........
    I take it that it's tapehead cleaner you are asking about (the cassette is the housing
    for the tape). In short, there are really no bad products, at least none I've seen or
    heard about.
    I use clean IPA (IsoPropanolAlcohol) that can be bought under many names, such as
    f.e. carburettor alcohol which seems to be the cheapest.
    Cotton buds are good - first wet to shift the dirt then dry to wipe off the
    thin haze left by the IPA.
    Avoid using white spirit, it may attack the plastics in some tapeheads.
  • 06-02-2009 9:50 PM In reply to
    Thanks for your reply.
    I actually purchased a cleaning tape,
    MAXELL AUTOMATIC HEAD CAPSTAIN & ROLLER CLEANER TAPE
    for the purpose.
    What's your experience with those kind of products? or do you prefer cotton buds for the purpose?
  • 06-03-2009 11:18 AM In reply to
    • Dillen
    • Posts 5,008
    I never liked cleaning tapes and always preferred cotton buds.
    The cleaning tapes may be good as a fast solution, especially in hard-to-reach decks (car stereos etc.),
    and some are of better quality than others. Maxell sounds like quality to me.
    There are some wet-cleaning tapes too, where you put a couple of drops inside the cleaning tape cassette
    and let it play in the deck for some time, these may work better.
    Still, being a tech guy myself, I prefer the manual way.
    It may also be because I've done surgery a couple of times to remove stuck cleaning tapes.
  • 06-03-2009 1:18 PM In reply to
    Agree with Martin - the 9000 is very easy to clean and cleaning tapes can be abrasive. Isopropyl alcohol and cotton buds for me too! I know Tim uses the same.
  • 06-03-2009 11:21 PM In reply to
    Well, I guess then I just wasted my money.Big Smile
  • 06-04-2009 1:39 AM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    RedGrant:
    Do as I - use both methods to overcome the disadvantage of each individually.   I use a wet-type tape head cleaner from discwasher (using their cleaning fluid) followed by a Q-Tip moistened with rubbing (isopropyl) alcohol.
