I use the 9000 for music and the Ouverture (connected to my non B&O television and BL6000 speakers) for movies. The two systems are not masterlinked. Is there a way to avoid turning both on at the same time with the Beo4 remote? I use the 9000 more than the Ouverture. Something about changing options?
Difficult!!!
You have to set them both on option 5 but the point is that they will both switch on and off everytime you press e.g. Radio or any other command!!!
Still I cannot understand why you need both in the same room!!
Best regards
Spiros
Try A.OPT 1 (or2) for the Ouverture and A.OPT4 for BS9000. You have to press LINK before source, for example you want to activate BS9000 CD press LINK - CD. Ouverture won`t resond. Same thing vice versa. Hope this helps.
Stefan
Hi, I have the same issue, Beosound 9000 for CD's etc and a Beosystem 5500 for LP's and tapes etc, although it also has a CD....
Will this work in that setup as well?
Cheers
GUY
Train Hard - Run Fast - Hit to Kill!!!
...why not? Take care that only the audiomaster you want to set the option to can "see" your remote. Disconnect the other one from the mains.
