Latest post 05-31-2009 4:53 AM by stefan. 4 replies.
Page 1 of 1 (5 items)
  • 05-30-2009 10:12 PM
    BeoSound 9000 and Ouverture in same Room
    I use the 9000 for music and the Ouverture (connected to my non B&O television and BL6000 speakers) for movies. The two systems are not masterlinked. Is there a way to avoid turning both on at the same time with the Beo4 remote? I use the 9000 more than the Ouverture. Something about changing options?
  • 05-30-2009 11:33 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: BeoSound 9000 and Ouverture in same Room
    Difficult!!!
    You have to set them both on option 5 but the point is that they will both switch on and off everytime you press e.g. Radio or any other command!!!
    Still I cannot understand why you need both in the same room!!
    Best regards
    Spiros
  • 05-31-2009 2:38 AM In reply to
    • stefan
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Try A.OPT 1 (or2) for the Ouverture and A.OPT4 for BS9000. You have to press LINK before source, for example you want to activate BS9000 CD press LINK - CD. Ouverture won`t resond. Same thing vice versa. Hope this helps.
    Stefan
  • 05-31-2009 2:59 AM In reply to
    Hi, I have the same issue, Beosound 9000 for CD's etc and a Beosystem 5500 for LP's and tapes etc, although it also has a CD....
    Will this work in that setup as well?
    Cheers
    GUY
    Train Hard - Run Fast - Hit to Kill!!!
  • 05-31-2009 4:53 AM In reply to
    • stefan
    • Posts 1,733
    ...why not? Take care that only the audiomaster you want to set the option to can "see" your remote. Disconnect the other one from the mains.
    Stefan
