I just purchased a Beomedia 1 and before hooking it up to my main system I tested it without any problem using a computer monitor/VGA cable. However, when I connected it to my Beosystem 1 ,I do not get any picture on my Pioneer Plasma. I followed the instruction manual which recommends to use a S-Video cable from the BM1 connected to the BS1 V.AUX Input. The BS1 is connected to the Pioneer plasma using a VGA cable. I do receive BM1 sound and I can turn on the Beomedia with the Beo4 via the IR sensor connected to the Beosystem 1.
Is it a BM1 screen resolution set up issue or is the S-Video from the BM2 causing a problem with the VGA from the BS1 to the plasma?
Hopefully someone can help me
