Latest post 06-12-2009 11:41 AM by Michael. 1 replies.
Page 1 of 1 (2 items)
  • 05-18-2009 6:46 PM
    • docfr8
    • Not Ranked
    • Joined on 05-18-2009
    • Posts 1
    Beomedia 1 - Beosystem1
    I just purchased a Beomedia 1 and before hooking it up to my main system I tested it without any problem using a computer monitor/VGA cable. However, when I connected it to my Beosystem 1 ,I do not get any picture on my Pioneer Plasma. I followed the instruction manual which recommends to use a S-Video cable from the BM1 connected to the BS1 V.AUX Input. The BS1 is connected to the Pioneer plasma using a VGA cable. I do receive BM1 sound and I can turn on the Beomedia with the Beo4 via the IR sensor connected to the Beosystem 1.
    Is it a BM1 screen resolution set up issue or is the S-Video from the BM2 causing a problem with the VGA from the BS1 to the plasma?
    Hopefully someone can help me
  • 06-12-2009 11:41 AM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-23-2007
    • Atlanta, USA
    • Posts 318
    Re: Beomedia 1 - Beosystem1
    If you haven't already resolved this than you've got a few variables to set aside.  I would recommend a simple test to see if you can get a source  (DVD?) to play through the BS1 to establish first that you've got the BS1 set up properly to display from that input.  S-video resolution shouldn't be a factor so you if you've confirmed that the BS1 isn't the issue than I would confirm that the BM1 is outputting S-video.  I don't have a BM1 so I can't help with that but I would guess that there may be an output setting in the menu that you may want to select while attached to the computer monitor.
    -Michael
