I have on my desk a Beogram 7000 which has been mishandled sometime in the past. The wire drive for the arm carriage is detached, unfortunately so that the "holder H" (as designated in the service manual) has snapped off. It's still there, hanging on the spring, but I can't seem to locate exactly where it should be. Does anyone have a photo of the area where it can be seen?
Seems like a flimsy part and probably not the first one that has snapped off. The white plastic doesn't seem to be such type that I'd have much luck with superglue. I was planning to drill a small hole in the carriage and epoxy a small metal peg into it - anybody have easier or more feasible patents thought of already?
