Hi,I've just discovered the following:If your music has NO cover, the Beosound 5 shows a default cover (white sphere or s.th. like this).It is possible to exchange that for your own picture :-)There are 3 files in the Beomaster/Data directory:- 0coverDefaultSmall (PNG)- 0coverDefaultMedium (JPG)- 0coverDefaultLarge (PNG)You can replace these files with your own pictures!I've just tested it with the "0coverDefaultLarge" png file and it works like a charme.Be sure to make a backup of the original files and rename them e.g. "backup_0coverDefaultLarge.png" and then copy your own file into the directory.Use an image editor to identify the dimensions of the picture. I tested the large picture (500x500 pixel).
I find the coverimage at google.dk and then change the name to Folder.jpg and it works fine.
I put in a picture on my daughter on one album, thats fun, brgds Ingvar
Collector since 1996, BS5/BM5, BL3*4, BL11, BEO6, BV10-46, BL2000, MX4002, Beocom6000, Beotalk1200
I didn't refer to covers of the original album:
The BS 5 uses default pictures if it can not find any album cover and I changed the systems default picture!
