Latest post 05-13-2009 12:56 AM by TWG. 3 replies.
Page 1 of 1 (4 items)
  • 05-12-2009 11:00 AM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    No Cover? Use your own picture instead of B&O original
    I've just discovered the following:
    If your music has NO cover, the Beosound 5  shows a default cover (white sphere or s.th.  like this).
    It is possible to exchange that for your own picture :-)
    There are 3 files in the Beomaster/Data directory:
    - 0coverDefaultSmall   (PNG)
    - 0coverDefaultMedium   (JPG)
    - 0coverDefaultLarge   (PNG)
    You can replace these files with your own pictures!
    I've just tested it with the "0coverDefaultLarge" png file and it works like a charme.
    Be sure to make a backup of the original files and rename them e.g. "backup_0coverDefaultLarge.png" and then copy your own file into the directory.
    Use an image editor to identify the dimensions of the picture. I tested the large picture (500x500 pixel).
  • 05-12-2009 1:31 PM In reply to
    • mite
    • Not Ranked
    • Joined on 07-24-2007
    • Posts 10
    Re: No Cover? Use your own picture instead of B&O original
    I find the coverimage at google.dk and then change the name to Folder.jpg and it works fine.
  • 05-12-2009 4:40 PM In reply to
    I put in a picture on my daughter on one album, thats fun, brgds Ingvar
    Collector since 1996, BS5/BM5, BL3*4, BL11, BEO6, BV10-46, BL2000, MX4002, Beocom6000, Beotalk1200
  • 05-13-2009 12:56 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    I didn't refer to covers of the original album:
    The BS 5 uses default pictures if it can not find any album cover and I changed the systems default picture!
