Latest post 05-12-2009 10:29 AM by Sandrikor. 3 replies.
Page 1 of 1 (4 items)
  • 05-12-2009 9:49 AM
    BV 7- 40 MKII or MKIII
    Can someone Tell me if this BV7 is MKII or MKIII ?     Type No: 9376
        Item No: 1818900
        Serial No: 20943057
    Thnx in Advance....
  • 05-12-2009 10:08 AM In reply to
    Re: BV 7- 40 MKII or MKIII
     I can't tell if it's a mark II or a mark III  (someone will be able to)...But the mark III is the one to have if your thinking about buying a Bv7-40 it's easy to tell as the display on the right is in white also has the Beosystem 3 in it with 4 Hdmi's on the back of it and you can up grade to add blu-ray and the new sound board to it later on. or just buy the new mark IIII thats coming out with it in.
    Hope thats Helpfulish! And good luck.
    Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
  • 05-12-2009 10:13 AM In reply to
    Hej S,
    Its a MKIII..
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 05-12-2009 10:29 AM In reply to
    Already Own it , just checking because if thats the case going to upgrade it with a blu ray player;) Great to hear ;) Thnx ^^
