I can't tell if it's a mark II or a mark III (someone will be able to)...But the mark III is the one to have if your thinking about buying a Bv7-40 it's easy to tell as the display on the right is in white also has the Beosystem 3 in it with 4 Hdmi's on the back of it and you can up grade to add blu-ray and the new sound board to it later on. or just buy the new mark IIII thats coming out with it in.
Hope thats Helpfulish! And good luck.
Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
