Latest post 05-11-2009 4:43 PM by ........... 1 replies.
Page 1 of 1 (2 items)
  • 05-11-2009 3:37 PM
    • Olof
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Posts 141
    HELP Does my Beosound 3 has an error ?
    When i try to programm the wake up timer (1.pressing TIMER, 2. pressing store) the wake time starts flashing in the display. I also cant change the wake up time by using the arrow buttons ? The system is connected with the wallplug.
  • 05-11-2009 4:43 PM In reply to
    Re: HELP Does my Beosound 3 has an error ?
    You need to set the clock first.
    Set the built-in clock
    > While the system is in standby, press and hold
    ST.BY until the time
    blinks in the display. If no time is set, the display shows ‘- -.- -’ instead
    of digits.
    > Press up or down to find the correct time. Holding down a button
    accelerates the search.
    > Press
    STORE to store the correct time.
    > To see the time permanently in standby, press
    ST.BY while the system is in standby. Press ST.BY
    again to cancel time viewing in standby.
    And to set up the timer function:
    Make a Wake-up Timer
    The Wake-up Timer is a once-only Timer, and must be programmed each
    time you wish to use it.
    TIMER. The time for the latest
    Wake-up Timer is shown in the display. The digits blink.
    > Press up or down to find the time you want the system to start playing.
    Press and hold up or down to step quickly to the desired time.
    > Press the button of the source you want to use for your Wake-up timer;
    RADIO or A MEM. ‘Pr’ (for a radio program) or ‘A’ (for A MEM)
    is shown in the display. If you do not choose a source, the radio is used.
    > Press
    STORE to store the Wake-up Timer. The time for the Wake-up Timer is briefly shown in the display.
    Check or delete a Wake-up Timer
    TIMER. The time for the Wake-up Timer blinks in the display.
    > Press
    STORE to confirm your Wake-up Timer, or…
    > …press
    DELETE to delete the Wake-up Timer. ‘-.--’ is shown briefly in
    the display.
    Snooze
    You can activate a snooze function when a Wake-up Timer switches on
    the radio or starts memory card playback. Pressing any button or turning
    the wheel within the first ten seconds switches off the system for ten
    minutes, after which the Wake-up Timer is executed once more. You can
    activate the snooze function as many times as you like.
    Hope this helps! :-)
