Latest post 05-05-2009 4:13 PM by Toralfsen. 6 replies.
Page 1 of 1 (7 items)
  • 05-04-2009 12:33 PM
    Same floorstand for BV6-26 and BV7-32?
    can someone help me with that? It is the one with motor I am talking about...
  • 05-04-2009 1:06 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Same floorstand for BV6-26 and BV7-32?
    Hi
    Essentially they are the same in the respect that the mounting bracket at the top is the same size.  However, there are two types i have come across in my time - one with a cut-out to mount the BeoLab 7.1 support plate into, and one with a plain pole and no cut-out.
    Always totally unplug the TV before plugging in the motor stand by the way - you can cause damage to the TV if you plug it in with the TV powered up.
    Lee
  • 05-04-2009 1:21 PM In reply to
    Ok, so if there is no cut-out then it's not possible to mount the 7-1 on it?
  • 05-04-2009 2:38 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Thats correct.  The cut out you need to mount the 7.1/7.4 bracket into is rectangular with two screw holes and is positioned roughly half way up the stand. It sometimes has a black plastic trimplate that slots into it for when it's being used with the BV6/BC6.
    Lee
  • 05-04-2009 5:08 PM In reply to
    OK, was hoping to be able to use the old stand on the new TV, but then I have to buy a new stand....
  • 05-04-2009 5:41 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Only a thought, but you could try ordering the pole section with the cutout and simply swapping it for the plain section... it could be a spare part that can be ordered from your local service center or dealer?
    Lee
    Smile
  • 05-05-2009 4:13 PM In reply to
    Thanks, that is a good idea, I will try that!Smile
