Latest post 04-15-2009 6:56 AM by Medogsfat. 5 replies.
Page 1 of 1 (6 items)
  • 04-14-2009 2:41 PM
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Beolink 1000 functionality with a Beomaster 6500
    I feel I should know the answer to this, but.....Embarrassed
    Is it possible to tune the Beomaster and then set the pre-set radio channels with a Beolink 1000 or do you need a MCP?
    I think I recall that one thing you can't do with a 1000 is set the timer function - is there anything else that can't be done with a 1000?
    Cheers
    Nigel
  • 04-14-2009 3:28 PM In reply to
    Re: Beolink 1000 functionality with a Beomaster 6500
    This was one of my first questions on Beoworld, so I know how you feel Smile
    Yes, BL1000 is enough for tuning and programming the presets. Use GOTO and then key in the frequency to tune into - the display turns to "F", and that's all the feedback you're going to get. You will need to key in the tenths as well, i.e 1040 is 104.0 MHz. Be patient until the BM actually tunes (there's a timeout).
    Then, if you want to store the current frequency to a preset, press STORE <preset number> STORE and you're done.
    h1npw:
    Yes - resetting the timer function! You will need to use the same remote that was used to create a timer to get rid of it. Another thing lacking will be the programmed play functions.
    -mika
  • 04-14-2009 7:01 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    The timer can be disabled without the original remote control though. In fact it can be done with no remote at all - just hold both buttons on the front of the receiver and it toggles between Timer On and Timer Off.
     Weekly top artists:
  • 04-15-2009 4:23 AM In reply to
    • h1npw
    • Posts 776
    Many thanks tournedos & Alex!
    Cheers
    Nigel
  • 04-15-2009 5:21 AM In reply to
    • ChrDH
    • Top 150 Contributor
    • Denmark
    • Posts 493
    Alex:
    Clever, I didn't know that
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 04-15-2009 6:56 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Alex is correct to a dgeree - this will stop the activation of the timer functions but the programs will still be there. The only 2 ways of cancelling the programs are to use the remote type which programmed them in the first place (which could be any of - MCP5500, MCP6500, Beolink 7000 or Beolink 5000) or remove the back up battery inside for 10 minutes.
    Chris.
