lubrication somewhere inside the cassette deck mechanism.
i would suggest getting the service manual and pulling out the mechanism and giving everything a good clean. i used circuit board cleaner/contact cleaner to remove the old grease which had dried and gone quite hard and then relubricated with a new grease... fixed all my problems.
Andrew
