Latest post 04-16-2009 3:45 AM by Dillen. 4 replies.
Page 1 of 1 (5 items)
  • 04-13-2009 4:25 PM
    Beocord 8000
    I recently bought a Beocord 8000 which was working perfectly.
    The other day I went to play a tape and it keeps kicking it out of play mode and I also don't hear the motor running .
    The belts are new .
    Any ideas ?
    George
    Filed under:
  • 04-13-2009 5:11 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocord 8000
    Voltage on motor ?
    Motor fuse blown ?
    Motor blown ?
  • 04-14-2009 11:25 PM In reply to
    • Andrew
    • Not Ranked
    • Joined on 03-16-2009
    • Melbourne, Australia
    • Posts 49
    Re: Beocord 8000
    lubrication somewhere inside the cassette deck mechanism.
    i would suggest getting the service manual and pulling out the mechanism and giving everything a good clean. i used circuit board cleaner/contact cleaner to remove the old grease which had dried and gone quite hard and then relubricated with a new grease... fixed all my problems.
    Andrew
  • 04-15-2009 8:15 PM In reply to
    Re: Beocord 8000
    Hi Martin,
    This is George . I was wondering if you know where I can find a motor for the Beocord 8000 ? Or maybe you have one and if so how much do you want for it ?  Please let me know.
    Thank you
    George
    Filed under:
  • 04-16-2009 3:45 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Beocord 8000
    I have new motors but check first if the motor gets any power at all.
    About 12-14V should be expected.
