Latest post 03-18-2009 5:29 PM by Jandyt. 1 replies.
Page 1 of 1 (2 items)
  • 03-18-2009 11:55 AM
    Is this a failure or is it working as designed? —Beocom 1 vs. Beocom 6000 Mk1
    On my Beocom 6000 Mk1 registered to its pyramid base, if a separate phone (say, a Beocom 2400) is off-hook, the indicator light on handset flashes red.
    On my Beocom 1 registered to its Beoline base, if a separate phone (say, a Beocom 2400) is off-hook, the indicator light on handset does not flash.
    Since I do not have another Beocom 1, I have no way of knowing if the light on Beocom 1 is supposed to flash when another Beocom 1 handset registered to the same Beoline is using the line, or if this is a failure.  The manual is not clear on this.  Here is what the manual says:
    s
    This is not a failure of the red LED, by the way.  The LED does flash when there is an incoming call, so I know it is functional.
    Beocom 1 software: handset sw v 1.70 mar 18 2004 / base v. 1.90 may 8 2006 / prod jul 28 2005
    Thanks in advance for your comments.
    Filed under: ,
  • 03-18-2009 5:29 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Is this a failure or is it working as designed? —Beocom 1 vs. Beocom 6000 Mk1
    I don't think it's a fault Xavier.
    The led will only flash if a handset that is registered to the Beoline base is in use........I think!
    Andy T.
    Poor me, never win owt!
