On my Beocom 6000 Mk1 registered to its pyramid base, if a separate phone (say, a Beocom 2400) is off-hook, the indicator light on handset flashes red.
On my Beocom 1 registered to its Beoline base, if a separate phone (say, a Beocom 2400) is off-hook, the indicator light on handset does not flash.
Since I do not have another Beocom 1, I have no way of knowing if the light on Beocom 1 is supposed to flash when another Beocom 1 handset registered to the same Beoline is using the line, or if this is a failure.  The manual is not clear on this.  Here is what the manual says:
s
This is not a failure of the red LED, by the way.  The LED does flash when there is an incoming call, so I know it is functional.
Beocom 1 software: handset sw v 1.70 mar 18 2004 / base v. 1.90 may 8 2006 / prod jul 28 2005
Thanks in advance for your comments.
