Hello;
I'm after a Beogram CDX in excellent condition. My question is if this will be suitable for connection to my BM4400. I understand the CDX could be conencted just as a normal Beogram to the phono connection. Am I right?
thanks!
Gustavo
You can't use the phono input, since there's the RIAA preamp of the BM4400 in the way. But you can plug the CDX to either tape 1 or tape 2 and it will work just fine.
-mika
I use a CDX with my 4400. You need a DIN to RCA adapter. I use it through Tape 2.
Thanks a lot Peter and Mika.
