Latest post 02-28-2009 4:52 PM by beobeo. 3 replies.
Page 1 of 1 (4 items)
  • 02-28-2009 7:34 AM
    • beobeo
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Spain
    • Posts 953
    Beomaster 4400 with Beogram CDX
    Hello;
    I'm after a Beogram CDX in excellent condition. My question is if this will be suitable for connection to my BM4400. I understand the CDX could be conencted just as a normal Beogram to the phono connection. Am I right?
    thanks!
    Gustavo
  • 02-28-2009 7:52 AM In reply to
    Re: Beomaster 4400 with Beogram CDX
    You can't use the phono input, since there's the RIAA preamp of the BM4400 in the way. But you can plug the CDX to either tape 1 or tape 2 and it will work just fine.
    -mika
  • 02-28-2009 11:25 AM In reply to
    I use a CDX with my 4400. You need a DIN to RCA adapter. I use it through Tape 2.
  • 02-28-2009 4:52 PM In reply to
    • beobeo
    • Spain
    • Posts 953
    Thanks a lot Peter and Mika.
    Gustavo
