I have a beocord 5000 in which i have replaced the belts. Now it starts, play the tape for 10 seconds and then shuts down. If i connect it to the beomaster, the whole system shuts down...
any hints???
Is it sounding fine while playing ?
Does both tape reels rotate while playing ?
Will it Wind/Rewind ?
everytning is ok, i have replaced the belts. Take up reel works as it should. Maybe it's a little bit slow on "loading" tape (when the heads is moving into the tape) Counter works.
//Erik
So wind/rewind is fine in that it will wind/rewind a full tape length without stopping ?
Did you replace all three belts ?
