Latest post 01-27-2009 11:36 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 01-26-2009 7:05 PM
    Beocord 5000
    I have a beocord 5000 in which i have replaced the belts. Now it starts, play the tape for 10 seconds and then shuts down. If i connect it to the beomaster, the whole system shuts down...
    any hints???
  • 01-27-2009 8:35 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocord 5000
    Is it sounding fine while playing ?
    Does both tape reels rotate while playing ?
    Will it Wind/Rewind ?
  • 01-27-2009 11:14 AM In reply to
    Re: Beocord 5000
    everytning is ok, i have replaced the belts. Take up reel works as it should. Maybe it's a little bit slow on "loading" tape (when the heads is moving into the tape) Counter works.
    //Erik
  • 01-27-2009 11:36 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Beocord 5000
    So wind/rewind is fine in that it will wind/rewind a full tape length without stopping ?
    Did you replace all three belts ?
